Forum Index > Off-topic Talk > Hollow ground blades in battle Reply to topic
C Bosh
PostPosted: Sun 16 Aug, 2009 10:50 pm    Post subject: Hollow ground blades in battle         Reply with quote
I am a keen fan of the sword in the wallace collection A-459 and have even had a couple made for me. I also like the sword of Hhenry V. I was wondering :How practical would a hollow ground sword be in battle against armoured opponents ? I have seen some hollow grinds edge fold when the angle of attack for the cut was wrong. Cheap swords ?
My forger also hammers in most of the supposed hollow grind during the forge.
my regrets for my English
Peter Johnsson
PostPosted: Sun 16 Aug, 2009 11:06 pm    Post subject:         Reply with quote
A blade with concave edge bevels, or hollow ground cross section can be very strong. Still, anything made by man can be destroyed by man. Swords break, armour dent and men die in war.
That hollow ground blades were practical, or functional in practical fighting, there should be no doubt.
Some original swords that I have seen have had very thin edges indeed. These were weapons made during the age of plate armour. That such edges would have folded on contact with steel armour did not prevent them being made. I do not think they were the result of mistake, but intentionally made so.
Swords have never been very good at defeating armour. Instead you want a blade that can reach behind or inbetween gaps. You can also aim for openings.
In the end, if you survive, but your sword gets nicks, you are still the winner of the fight.
One hollow ground section can be very different from another. The thickness of the spine, width of blade and radius of the hollow all plays a part in how much material is left or removed. Also of great importance is how much thickness is left in the very edge where the sharpness is shaped (normally with an apple seed section).
Of the many original blades with hollow ground section that I´ve seen many have rated in the highest level of quality.
C Bosh
PostPosted: Sun 16 Aug, 2009 11:53 pm    Post subject:         Reply with quote
Thank you for your reply., I just wondered if there main wearing was more civil than military? A sword of choice for some and not for others on the battle field , like most things.
Thank you
Morgan Butler
PostPosted: Mon 31 Aug, 2009 1:49 pm    Post subject:         Reply with quote
In the 18th cen, many officers carried hollowground blades with smallsword type hilts. And not just because they were staff officers who were not expecting to fight. Many line officers who marched in the field with a troop of infantry carried these type of weapons. They were broad enough to parry a heavier weapon and gave a very stiff thrust that would penetrate a heavy uniform coat. Here are some pics of one kind of military hollowground sword. It is very business-like.
 Attachment: 31.85 KB
 Attachment: 29.6 KB
 Attachment: 22.18 KB
 Attachment: 21.63 KB
inkothemgard!
PostPosted: Mon 31 Aug, 2009 2:02 pm    Post subject:         Reply with quote
An advantage of the hollow grind is that one can get a thicker spine in the center compared to a diamond cross section of the same mass. This can make a blade stiffer in thrusting than it would have been otherwise (comparable mass in a more thin lenticular cross section.) I envision the result as possibly more versatile if used judiciously; thrusting against plate, cutting against soft targets.
