Forum Index > Historical Arms Talk > Butted Mail in Europe Reply to topic
Will S
PostPosted: Mon 25 Nov, 2013 3:22 pm    Post subject: Butted Mail in Europe         Quote
Hi guys, I've just joined this forum (although have been lurking/reading stuff on here for ages!)
The reason I'm posting is because while reading Alex Hildred's Weapons Of Warre (The Armaments of the Mary Rose) there''s a chapter regarding armour and mail found on the ship when it was recovered.
It turns out that amongst the mail were numerous items (I think about 19) of mail made from a mixture of butted and riveted mail. I've never heard of this before, but they're documented, photographed and analysed in the book. The ship sank in 1545, and as far as I've been aware butted mail just wasn't used during that period in Europe. It's especially odd to find butted mail in the same piece as riveted mail. The majority of the items seem to be butted, with edges and small areas being riveted.
My question - is this completely unknown outside the Mary Rose, or are there other existing/documented examples of butted mail from around the 15th Century (perhaps earlier/later) and more interestingly are there other examples of mail clothing/armour with a combination of butted and riveted mail all in the same piece?
Thanks!
Profile PM E-mail
PostPosted: Mon 25 Nov, 2013 4:26 pm    Post subject:         Quote
I thought that the few pieces of mail found on the Mary Rose were decorative links made of leaded brass.
Edit: According the the Mary Rose Trust database there are 31 pieces of mail but some of these aren't mail at all but clothing fasteners. The rest could be decorative copper alloy links of butted mail. Except for one - #82A6000 - which is listed as made of both copper alloy and iron butted links. Assuming it actually is armour, the fragment is too small to learn anything useful from it, but there is no reason to think that the few butted iron links were not a repair.
Mart Shearer
PostPosted: Mon 25 Nov, 2013 5:11 pm    Post subject:         Quote
https://s-media-cache-ec0.pinimg.com/originals/8c/26/e2/8c26e26409f4f3df9e2eaba02a61173b.jpg
It's hard to define most of these as mail rather than chains or closure rings.
The brass "ermine-tails" applied to the British Museum standard with the 6:1 collar are also "butted".
 Attachment: 87.67 KB
 Attachment: 154.18 KB
Will S
PostPosted: Mon 25 Nov, 2013 5:15 pm    Post subject:         Quote
Ah ok, so it's safe to assume then that the butted mail was essentially a quick method of adding decoration, and had no strength/defensive attributes? Makes sense!
Cheers for the quick replies!
Profile PM E-mail
Anthony Farrow
PostPosted: Mon 25 Nov, 2013 11:50 pm    Post subject:         Quote
Interesting. Do you have any more information regarding this standard? I reproduced a standard - admittedly with butted links - with the same 6:1 pattern on the neck as it seemed to sit better, and provided a better platform for my armet to rest over and turn.
Mart Shearer
PostPosted: Tue 26 Nov, 2013 6:53 am    Post subject:         Quote
Anthony,
The British Museum page has a bit more information like dimensions and weight.
http://www.britishmuseum.org/research/collect...amp;page=1
Here's the close-up of the collar:
Thom Richardson's thesis indicates these were likely categorized as "pisanes" in 14th century inventories.
http://etheses.whiterose.ac.uk/3919/1/Thom_Ri..._final.pdf
Only one form of mail collar is found Fleet’s account, the pisane. A surviving
example of this type of defence datable to the fourteenth century from London is the
mail collar in the British Museum, from the Roach Smith collection
which was found on London Wall, Moorgate, and could conceivably therefore be
one of the collars of mail originally from the Tower. This exhibits numerous interesting
features, having alternate rows of riveted and solid links, a border of riveted links
of latten, pendant dags of butted links of latten (which are mostly lost due to the
fragility of this construction), and a most unusual collar section formed of riveted
and solid links connected to three links above and below, making a remarkably dense
form of mail. The decorative dags of latten links clearly show that this collar was
intended to be worn on top of any other garments, whereas in artistic representations
of the period generally only the section worn round the neck is visible, the rest
hidden under the coat of plate or the surcoat. In modern times the term pisane has
come to represent a mail cape rather than a collar, of the type sometimes called a
‘Bishop’s mantle’ in the terminology used by collectors of armour.
It is possible that the collar is a later addition done during the working life of the piece, as Erik Schmid believes the collar to be 16th century, but the demi-riveted construction in an English context seems to indicate <c.1340. The later date might also explain the addition of the butted dags which would be visibly worn.
http://forums.armourarchive.org/phpBB3/viewto...mp;t=29220
Erik D. Schmid wrote:
As for the standard in the British Museum it does indeed have a collar woven in the 6-1 pattern. Judging by the style of links used in the collar I would place it in the sixteenth century.
Thom Richardson wrote:
The evidence in the Tower accounts shows that the traditional date of 1400
before which European mail was made of half-riveted, half solid links, needs to be
revised to about 1340.
Eric S
Reading list: 8 books
PostPosted: Tue 26 Nov, 2013 7:00 am    Post subject:         Quote
Museum number:1856,0701.2244
Description:Mail collar or standard, of iron and copper alloy, covering the neck and extending onto the shoulders. The section for the neck is formed of riveted mail links, each connected to three links in the rows above and below (1:6). The lower section is of alternate rows of riveted and welded links, and is shaped to fall in points over the shoulders and at the centre rear. The lower edge and centre portion of the upper edge are formed of riveted copper alloy links. Around the base of the neck section is an intermittent row of butted copper alloy links, from which three remaining decorative mail triangles, also formed of butted copper alloy links, and part of a fourth, fall. At the right end of the colllar is the base of an iron clasp, with a large washer on the inside. A few links are missing, leaving a hole at the centre right and smaller holes at the centre and left.
Date:1350 (circa)
Made in: England (?)(Europe,United Kingdom,England)
Materials:iron, copper alloy
Dimensions: Width: 670 millimetresDepth: 10 millimetresHeight: 260 millimetresWeight: 1010 grammes
Curator's comments:The 1:6 ratio of mail on the collar is extremely rare. Mail collars of this sort, called standards or pizanes, are recorded in large numbers in the inventories of the Tower of London arsenal in the late 14th century.
http://www.britishmuseum.org/research/collect...p;partId=1
Profile PM Website
Eric S
PostPosted: Tue 26 Nov, 2013 7:07 am    Post subject: Re: Butted Mail in Europe         Quote
Can you post one of the photographs, I have heard of solid links being described as "butted" when the ends are butted together and welded, I would be nice to find out if the links were actually butted as it could just be a matter of the links in question not being described properly.
Profile PM Website
Will S
PostPosted: Tue 26 Nov, 2013 2:03 pm    Post subject:         Quote
I apologise for the quality - these are photos I've taken of the photos in the book!
I don't know enough about maille to have the first clue what sort of item of clothing this was, but it does seem that the majority of the rings are butted, although riveted links can clearly be seen at the top of the first photo.
Hope this helps?
Profile PM E-mail
Mart Shearer
PostPosted: Tue 26 Nov, 2013 6:53 pm    Post subject:         Quote
And the link, again, for those who missed it the first time.
For those who have difficulty clicking a link,
[ Linked Image ]]
The butted rings appear to be the latten edging on riveted iron rings.
Eric S
PostPosted: Wed 27 Nov, 2013 2:03 am    Post subject:         Quote
Hope this helps?
Thanks Will. your right, the photograph clearly shows riveted links and butted links, its unfortunate that this is only a small patch of mail and not a whole armor. The only time I see mail in this arrangement is when the butted links have been used as a repair to a riveted mail with holes. Here is an image of some Indian riveted and solid link mail with butted links added at a later date to repair holes and to fill in for missing links. I can not think of any other reason to mix riveted and butted links together.
Profile PM Website
PostPosted: Wed 27 Nov, 2013 2:27 am    Post subject:         Quote
There is only a single mention of iron mail in the Mary Rose database. Item number 82A6000 is listed as a combination of copper alloy and iron links. As far as I know, the patch of mail in the bottom right corner of Mart's photo is that piece. The black and white photo is not of that piece, it is another, much larger, patch of mail. I might have missed it but I looked through every single one of the 14000+ entries in the Mary Rose database and found no mention of it. Perhaps someone else can find it for me.
http://www.maryrose.org/discover-our-collection/archive/
Will S
PostPosted: Wed 27 Nov, 2013 3:26 am    Post subject:         Quote
Ah well I can help with that.
The item number for the larger piece of mixed links is MR 83A0153.
If I may, I'll quote from the book in regards the mail found:
"Nineteen fragments of mail were excavated from the Mary Rose. Additional mail links were recovered during the sieving of spoil heaps in 2003. Some of the recoveries comprise several pieces. Nine samples were analysed by E.E.H. Pitt for composition using XRFS. All proved to be leaded brass.
No complete garments are present. Many fragments are only one link deep, linked laterally and resembling a chain. It is likely that these fragments are decorative edging of larger items of mail made of iron which have corroded away. Several fragile examples are still within concretion and radiography suggests the presence of iron links.
There are three examples with mixed link types, all more than one link deep. One is a mixed butted and riveted piece with circular cross section (81A0918) and the other two are mixes of butted, overlapped semicircular and overlapped circular cross section. The largest fragment recovered is (83A0153). It was foumd in concretion during the cleaning of the ship. It was recovered from the area of the Carpenters' cabin amd was associated with iron concretion."
Profile PM E-mail
Will S
PostPosted: Wed 27 Nov, 2013 3:38 am    Post subject:         Quote
Just realised I have a table of details as well which isn't on the MR website if anybody's interested?
I'll post the details for the large fragment of mixed links but if anybody finds a record of MR mail that interests them I'll happily do the same for those.
83A0153
Sector - M9
Form - "frag. of 92 links, 1:4 formation, max. 14 x 13 links, rivet slot 3 x 1mm."
Comprising: 70 butted, 12 riveted, 10 riveted round cross section
Length - 115 x 100
Weight - 24.8
Link ext diam. - 11
Link int. diam. - 7
Wire thickness: Butted - 2, Riveted - 1.5
Profile PM E-mail
PostPosted: Wed 27 Nov, 2013 4:07 am    Post subject:         Quote
I found that one already but the entry in the database made no mention of iron links. In any case, I agree with the others that any riveted mail with inclusions of butted mail are either decorations or repairs.
