Forum Index > Historical Arms Talk > Albion Solingen Opinions Needed Reply to topic
John Malick
PostPosted: Fri 30 Oct, 2015 3:02 pm    Post subject: Albion Solingen Opinions Needed         Reply with quote
Just curious if anyone here has owned or handled the Solingen by Albion and what your opinion of it is particularly it's cutting ability?
Thanks,
John
PostPosted: Fri 30 Oct, 2015 6:37 pm    Post subject:         Reply with quote
Have you read our hands-on review?
John Malick
PostPosted: Fri 30 Oct, 2015 7:02 pm    Post subject:         Reply with quote
Yes I did read the hands on review several times over the past few weeks. I was just hoping for a few more opinions also in the review unfortunately there is no mention of its actual cutting ability or how it behaves while cutting different mediums like bottles or mats or rolled news paper.
Craig Peters
PostPosted: Fri 30 Oct, 2015 10:35 pm    Post subject:         Reply with quote
I haven't seen anyone post a review on the Solingen's cutting performance. Speculating a little bit, I would imagine it cuts somewhat similar to a Type XII such as Albion's Knight. With the Knight it was not particularly difficult to cut through a piece of bone in lamb meat that was nearly one cm in diameter. I would imagine the Solingen should be able to perform comparably; although it has a slightly less wide blade near the point compared with the Knight, the Solingen sounds like it has a bit more presence and authority.
However, maybe someone who has actually cut with the Solingen can comment on it and provide pictures showing it in use.
PostPosted: Sat 31 Oct, 2015 12:21 pm    Post subject:         Reply with quote
http://myArmoury.com/talk/viewtopic.php?t=3203&highlight=
i will check. I think David Kite posted an informal picture report on how the edges held up to some tough cutting against a metal rimmed shield.
Sorry, the original post seems to have been replaced with the current more standardized review.
PostPosted: Sat 31 Oct, 2015 12:55 pm    Post subject:         Reply with quote
We wouldn't have replaced any posts. Not sure what you mean.
John Malick
PostPosted: Sat 31 Oct, 2015 9:19 pm    Post subject:         Reply with quote
In the review the durability of the sword is mentioned and because it is tested against chain mail, hit against another sword and against a steel buckler. The worst damaged came from hitting the other sword which is the damage you see in the picture. I just wish the author had mentioned how it actual performed while cutting different mediums.
Patrick Kelly
PostPosted: Sat 31 Oct, 2015 10:38 pm    Post subject:         Reply with quote
Years ago, I did some cutting with the Solingen prototype during a visit to Albion. I found it to be a good cutter against tatami mats. It's not quite as nimble as the Knight since it has a bit more blade mass, but a very nice example of the type.
Jeremy V. Krause
PostPosted: Sun 01 Nov, 2015 6:33 am    Post subject:         Reply with quote
Yes, I would agree.
I own a Solingen and like it quite a bit. I would say that the knight has somewhat more "sweet" handling characteristics.
J. Helm
PostPosted: Sun 01 Nov, 2015 1:19 pm    Post subject:         Reply with quote
Does anyone have any opinions/comments about the grip length of the Solingen? At 4.5 inches (according to David Kite's review) it seems a little longer than most one-handers. I have never seen any mention of it anywhere, so I assume most don't have a problem with it.
Jeremy V. Krause
PostPosted: Sun 01 Nov, 2015 4:06 pm    Post subject:         Reply with quote
Yes, there is plenty of room but I wouldn't describe the Solingen as having a "long" grip.
J.D. Crawford
PostPosted: Sun 01 Nov, 2015 4:47 pm    Post subject:         Reply with quote
It doesn't look that long. According to Kult of Athena its 4.0"
J. Helm
PostPosted: Sun 01 Nov, 2015 6:06 pm    Post subject:         Reply with quote
OK, perhaps there is an error in the measurements by one or the other. My Yeoman grip is 4" and it has extra room due to my small hands, so any more than that seems unnecessary to me, but I haven't handled many swords to know if that makes much of a difference. It sounds like folks don't consider it to be an issue either way in this case at least though. Thanks for the feedback.
