Forum Index > Makers and Manufacturers Talk > For sale: New bascinet with lining and avential Reply to topic
Piotr H. Feret
PostPosted: Sun 23 Apr, 2017 11:45 am    Post subject: For sale: New bascinet with lining and avential         Quote
Greetings
I have reproduction of bascinet dated for about 1340-1380 for sale - I have made it for custom order, however it's turn out little too big. It's new and never used - only for fittings.
Bascinet is made from two halves raised on hot from 2 mm high quality mild steel and welded together. It was heat hardened and tempered up to 40 HRC.
Hand sewn lining with height regulation (linen with wool felt amortization)
Close fitted riveted mail avential (wedge riveted) also with padding.
Fit perfectly for 58-59 cm head circumference.
Here are some sources:
http://effigiesandbrasses.com/3806/3362/
http://effigiesandbrasses.com/1300/5985/
http://effigiesandbrasses.com/3805/3361/
http://effigiesandbrasses.com/841/4424/
http://effigiesandbrasses.com/3088/6470/
Price: 2800 PLN + shipping cost
Images in higher resolution you can find here:
https://www.flickr.com/gp/128474793@N08/f2E33t
Please don't hesitate to contact me here or on platener@platener.eu or piotr.platener@gmail.com if you are interested in it or if you need any more information.
www.platener.eu
Profile PM Website
Piotr H. Feret
PostPosted: Fri 28 Apr, 2017 5:20 am    Post subject:         Quote
Few more information, which may be helpful:
Bascinet weight with inside lining - 2,350 kg
Bascinet weight with lining and avential - 3,960 kg which is about 8,740 lb
Ear to ear distance (with lining include) is 16,5 -17 cm
From the forehead to back of the head (with lining include) is 20,5 cm
Avential rings are 8 mm inside diameter and around 11 mm outside diameter.
Such bascinet will be for example good option for person recreating light men-at-arms not engage in full contact combat, however if someone will be interest I can make a visor for this bascinet, some klappvisier style one will suit here well.
www.platener.eu
Profile PM Website
Piotr H. Feret
PostPosted: Sat 13 May, 2017 10:56 am    Post subject:         Quote
Bascinet sold, thank you for viewing.
www.platener.eu
Profile PM Website
