Lancelot Chan
Shahril Dzulkifli
Posted: Wed 27 Jan, 2016 7:07 am Post subject: Cutting with a sharpened blunt from Longship Armoury. |
Just saw that video.
- Marcus Aurelius
Lancelot Chan
Matthew P. Adams
Posted: Sat 30 Jan, 2016 7:11 am Post subject: |
That bevel looks great! Excellent work and thanks for sharing.
Lancelot Chan
Posted: Sat 30 Jan, 2016 7:15 am Post subject: |
| Matthew P. Adams wrote: | | That bevel looks great! Excellent work and thanks for sharing. |
Yes. One thing about hand sharpening all the way was that I can ensure the bevels are symmetric! Which is hard to come by these days unless on high priced Japanese polish.
Posted: Sat 30 Jan, 2016 9:44 am Post subject: |
Hand sharpening can take a lot of patience and hard work but it's much easier to control and not screw up the edge.
Using a belt sander to start the bevel and finishing by hand is sort of a cheating shortcut but best to finish by hand if one has the skill due to years or decades of hand sharpening knives.
Using a bench stone wheel grinder is asking for a rough and very badly made secondary bevel due to vibration with most abrasive wheel type grinders.
With a blunt you will probably get a wider secondary bevel than with a sword made to be a sharp, but it will be a very robust edge.
The difference between a good cutting edge and the best cutting edge you can make. ( The poor victim would likely lose a limb from any decent cut either way ).
In any case your cuts look very clean ! Skill is also a factor I think because a very good cutter can get better cuts with a marginally sharp blade than a bad cutter can get with a razor sharp blade.
( Note writing this as I eat sushi and drinking some saki, so forgive any typos that the " Spellchecker " may have missed and that I might also miss ..... )
I guess one can praise your sharpening technique as much as your competence with actual cutting.
Lancelot Chan
Posted: Sat 30 Jan, 2016 9:51 am Post subject: |
Thanks again for your nice words.
Yes, I actually considered doing coarse grind with a work sharp tool but I dun own one. Plus I am quite sensitive to noise, with my wife even more so. So nah, that's outta question.
Have you checked the videos I just put up about our third visit to a friendly dojo for test cutting? I tried out some new techniques there (well, not so new but never cut tatami with them before).
Once again thanks for watching and your nice reply!
| Jean Thibodeau wrote: | Hand sharpening can take a lot of patience and hard work but it's much easier to control and not screw up the edge.
( Note writing this as I eat sushi and drinking some saki, so forgive any typos that the " Spellchecker " may have missed and that I didn't also miss ..... )
I guess one can praise your sharpening technique as much as your competence with actual cutting.  |
Posted: Sat 30 Jan, 2016 10:27 am Post subject: |
| Lancelot Chan wrote: | Thanks again for your nice words.
I may have missed some of your videos although I usual view most of them.
I've used a tungsten carbide sharpening tools to start the bevels on at least one Del Tin I hand sharpened as the aggressive carbide did a quick job of establishing the secondary bevels, but I did finish using a diamond hone and then ceramic hones.
Something like this on KoA, maybe not the same brand ? In any case the " V " shaped cutting edge on the tool does produce a symmetrical bevel, but it does tend to be wavy and rough and needs work to smoothen out with finer abrasive tools.
http://www.kultofathena.com/product.asp?item=...+Sharpener
Lancelot Chan
Posted: Sat 30 Jan, 2016 11:04 am Post subject: |
You can check the three links that I posted in reply. Those were the students' test cuts. You will notice that they were using the swords that I later tested with.
Accusharp works. Just that it set the angle already, which is good for those who dun want the freedom of screwing up.
I use diamond all the way, from 60 to 8000 grits, then finish with felt block.
| Jean Thibodeau wrote: | | Lancelot Chan wrote: | Thanks again for your nice words.
http://www.kultofathena.com/product.asp?item=...+Sharpener |
