Forum Index > Historical Arms Talk > Buff coat WIP Reply to topic
Danny Nguyen
PostPosted: Fri 12 Feb, 2016 9:40 am    Post subject: Buff coat WIP         Reply with quote
The torso pattern of the buff coat is ready, however I couldn't find a curve needle. Would a baseball stitch be a suitable replacement?
PostPosted: Fri 12 Feb, 2016 1:10 pm    Post subject:         Reply with quote
You can make your own curved needles.
Jeffrey Faulk
PostPosted: Tue 16 Feb, 2016 7:43 am    Post subject:         Reply with quote
Curved needles can also be found at most craft and hobby stores, as well as Walmart. They may be described as 'upholstery needles'.
Joel Minturn
PostPosted: Tue 16 Feb, 2016 1:00 pm    Post subject:         Reply with quote
You'll need to be careful because needles are often strong but brittle. That said I have made curved needles accidently when working on leather.
Danny Nguyen
PostPosted: Tue 23 Feb, 2016 4:52 pm    Post subject:         Reply with quote
Never mind I found some curved needles. Here is a photo of the torso held by duck tape. Is it too big? And does anyone know where I can find patterns for pre bent arm sleeve with integrated gussets?
 Attachment: 325.42 KB
Mark Griffin
PostPosted: Wed 24 Feb, 2016 2:15 am    Post subject:         Reply with quote
That's a good start, looking nice. Best of luck with the rest.
Danny Nguyen
PostPosted: Tue 22 Mar, 2016 5:04 am    Post subject:         Reply with quote
Here is the nearly complete coat. However, I am having problems with the armpit as its bunches up when I lower my arms. How to I correct this problem? Should I Leave a cut in the armpit and cover it with layers of cloth?
 Attachment: 188.88 KB
Reading list: 7 books
PostPosted: Mon 18 Apr, 2016 4:50 am    Post subject:         Reply with quote
Maybe you shouldn't make too much of a fuss about it if the bunching doesn't actually compromise your comfort or range of motion. It's precisely this bunching that gives you the extra material to let you raise your arms without lifting the body of the garment along.
