Forum Index > Historical Arms Talk > Work Hardened Bronze Reply to topic
Keith S.
PostPosted: Wed 05 Aug, 2020 9:12 am    Post subject: Work Hardened Bronze         Reply with quote
I have a question about work hardening bronze. I know that Neil Burridge works the material along the edges of his blades to make them harder. How ubiquitous was this practice, and when examining an antique, how does one tell that this has been done? Does it leave hammer marks? or are these polished out on most surviving examples?
Mikko Kuusirati
PostPosted: Wed 05 Aug, 2020 10:52 am    Post subject:         Reply with quote
Neil himself talks about this a bit in this video: https://www.youtube.com/watch?v=qGqPnzkRZp4
PostPosted: Wed 05 Aug, 2020 3:45 pm    Post subject:         Reply with quote
It seems to have been done fairly regularly with blades. The result produces a hardness that is similar to that of medium-carbon steel (non quench-hardened).
Paul Hansen
Likes: 5 pages
PostPosted: Thu 06 Aug, 2020 11:49 am    Post subject: Re: Work Hardened Bronze         Reply with quote
I think the vast majority (if not all) of bronze age swords had work hardened edges.
It also makes sense, it significantly increases the hardness (and thereby edge keeping ability) without adverse effects.
That depends a bit on the edge thickness. On thin edged blades (e.g. with a mid rib) the hardened edge is clearly visible as a kind of "secondary bevel".
On thicker edged blades, it can be more difficult to see.
Original with high detail photo's:
https://m.lauritz.com/en/auction/sword-ireland-bronze-1100-to-1050-bc-wilburton/i4191198
Keith S.
PostPosted: Fri 07 Aug, 2020 5:09 pm    Post subject:         Reply with quote
Thank you all for the responses! If there is a particularly thick bronze blade which has been polished and shows no hammer marks, is the presence of work hardening determined by testing the hardness of the blade on the core and edges? I created this thread because I will be examining some chinese dagger-axes sometime soon and I have not heard of them being work hardened, so I would like to see if I can tell myself.
Paul Hansen
Likes: 5 pages
PostPosted: Sat 08 Aug, 2020 1:03 am    Post subject:         Reply with quote
I suppose that any form of destructive testing is ouf of the question then... Wink (All hardness tests are somewhat destructive)
Any hammering will leave some kind of deformation.
I don't have the Khopesh pictured above but I do have a Naue II from Neil. It doesn't have the very clear hardened edge like on the Carpstoungue sword pictured above but more a kind of convex / lenticular profile with a slighty concave area towards the edge, if that makes sense. I did handle the Khopesh a couple of years ago, if I remember correctly, the profile is nearly purely convex.
If you have a good camera with a macro lens, you can try making a lot of close-up pictures. Would be really interesting to see!
Sean Manning
PostPosted: Sat 08 Aug, 2020 1:09 am    Post subject:         Reply with quote
The Chinese bronze weapons are a different technology than the European ones, they figured out some tricks like high-tin alloys which European smiths never did, and probably the reverse.
Jeroen Zuiderwijk did some research on both traditions, he hangs out on the Bladesmiths Forum and has a Facebook Page.
weekly writing
~ material culture
Keith S.
PostPosted: Wed 12 Aug, 2020 2:56 pm    Post subject:         Reply with quote
Thank you for the the info! I am aware of the high-tin bronze weapons in China, but many dagger-axes also fell in the standard 11-12% tin range, I am wondering if work-hardening was done on any of these.
