Posts: 1,525 Location: Sydney, Australia
Thu 18 Aug, 2022 5:34 pm
katana copypasta bold claims about Emperor suzakus laws
https://i.pinimg.com/564x/e1/86/7c/e1867ce589633e54ca929b9abc50a92c.jpg
So theres this 9Gag copypasta about the katana vs 'zweihander' (i presume they mean longsword)
and, one element especially stands out that , to sum up 'emperor suzaku made an edict in900AD that meant all swords had to be in the 'koto' style of tachi and that any attempts to 'improve' the design' would have their hands cut off or whatever
Also i have the feeling that these people have never heard of a sabre before... like the dao...
i feel.... that this is probably either grossly oversimplified or just flat out wrong but googling emperor suzaku and koto sword purity edicts and such have turned up nothing, except these sorts of reddit posts and images
Attachment: 175.73 KB
the biggest part of why this one bugs me
Thu 18 Aug, 2022 7:18 pm
Hi William,
As someone who is fairly biased towards long swords, I agree that these claims are distorted.
Swords are always designed with in mind being able to perform a particular actions well. That necessarily involves compromises, as particular shapes and forms will have advantages and disadvantages.
Calling the katana “a very weak sword” is misleading. Katanas are specialized cutting swords, and do their job very well. Any sword that has a curved, single edged cutting blade is going to cut more easily than a classic European sword. As an example, my Albion Soldat cut with the same depth and ease into a cardboard box as my Albion Tritonia, despite the fact that the Soldat weighs 955 grams versus 1.53 kg for the Tritonia. Likewise, any katana is a fearsome hewing weapon. While a katana may be poor against plate armour, its point can cause devastating wounds against lightly armoured opponents, as many would have been on Japanese battlefields. Therefore, saying that it being singled edged and curved and therefore lacking the basic elements of a decent sword is silly.
Also, the folding of steel thousands of times was not done as a scare tactic. It was based upon the fact that Japanese iron had a lot of impurities, and the folding was a way to compensate for these problems. I think very few of Japan's enemies knew that the weapons were folded many times, and even if they did, it certainly was not done as a “scare tactic”.
Describing that there were no improvements made to katanas is also a bit misleading. There are quite a number of different blade shapes and cross sections on katanas. The differences are not necessarily dramatic but they are present. One might similarly argue that European swords between 1050-1250 display “no improvements” because there aren't major changes in shapes in and forms between Type X to XII swords—but of course this oversimplifies, as does the statement about katanas.
Another thing the creator neglects to mention is that Zweihanders are comparatively heavy as swords, and that is not always an advantage. It is true they have tremendous reach as far as swords go. It is also true that they typically have a mass between 2 to 3 kg. When fighting for a prolonged period of time, this mass difference is exhausting, no matter how physically fit one is. Therefore, it's misleading to consider certain advantages of a Zweihander without considering their drawbacks.
Where the post has more validity is in noting that Japanese sword smiths seem to be less experimental than their European counterparts. I suspect that this was, to a degree, a result of the insular nature of many—though not all—Japanese conflicts. Perhaps an even greater factor, however, was that Europeans from the later 13th century onwards developed sophisticated forms of armour that, for the most part, were not found in Asia. Coats of plates and plate armour forced swords to evolve. Prior to coming into contact with Europeans, samurai probably rarely if ever faced armour that could easily defeat the katana. Given the tremendous hewing capacity of the katana and the kinds of armour it faced, there was not a lot of reason to modify the sword.
Nevertheless, European swords certainly tend towards greater versatility. Having a well developed cross gives the sword tremendous defensive capacity if employed for turning (winden) although this was probably less relevant in a battlefield situation. Even without turning, wider crosses seem to offer better hand protection. Lacking a second edge dramatically decreases the number of techniques available to a katana, which makes European swords more versatile. However, how many of these additional techniques would have been easy to employ in a battle, as opposed to one-on-one combat, is a valid question. In an unarmoured duel, there's a lot more you can do with a long sword, but when you face multiple attackers from different angles in the field, you may not want to be “tied up” the way you can be in a duel. A lot of the most useful core attacks for a battlefield like diagonal hews and vertical hews and thrusts that you can employ with a long or two handed sword can be employed with a katana.
All this to say that European swords do tend to have greater versatility in terms of the actions and techniques you can perform with them. Certain types, like XV.a, XVI.a, XVII, and XVIII.a are unambiguously better than katanas for dealing with plate armour—a defense katanas almost never had to face. However, the idea that katanas are weak and poor and deficient is silly. Katanas do very well at what they are designed to do. Given the circumstances in which they were employed, there was not a lot of reason to change their design. By the time katanas started to face European plate armour, European armies were already moving towards discarding armour as firearms made it increasingly obsolete. In such a context, there was no real reason to change the form of the katana.
Fri 19 Aug, 2022 3:55 am
I'm gonna guess this meme is either a deliberate attempt at trolling youngsters who have only just gotten into the "samurai sword" thing, or was created by the HEMA equivalent of such a person, or both.
Sat 20 Aug, 2022 4:43 pm
| Craig Peters wrote: |
Hi William,
i mean the mongols and chinese were using brigandines by the late 13th century i believe and to my mind, for all forms of practical necessity the single handed dao and the katana are the same sword.. and the dao was used a fair bit against said brigandine wearing mongols
and lamellar is in many respects like a proto brigandine in general armour niche.. especially rigid do-maru and such
Posts: 410 Location: Germany
Sun 21 Aug, 2022 10:46 pm
Without knowing much about katanas or Zweihänders I can tell that the basic argument is wrong, but there are some claims in the meme that could be fact checked and are possibly true independent of each other, that I am interested in knowing the answer:
1. Emperor Suzaku invented the koto sword design.
2. There were legal restrictions on sword design innovation.
3. Every Japanese weapon is single edged, curved and have no crossguard.
4. The steel in Katanas were folded a thousand times (I have heard that it was more like three times)
5. The Zweihänder has more design variations compared to the katana.
6. Blacksmiths consider the Zweihänder the best or an especially good weapon.
7. The Zweihänder weighs less than the katana and is twice as long with 2 times the reach.
I agree with those that think that this is designed to troll others, it has the right mix of absurdity and believability. That is, one can believe that someone thinks these things, but also think they are so wrong.
Wed 24 Aug, 2022 7:18 am
| Graham Shearlaw wrote: |
Folding is multiplicative, any good patten welding item will have a huge number of layers from just a few folds.
If you start with 6 layers you get 12, 24, 48,96,192,384,768 1536, that's just 8 folds so the million times myth does have good grounding.
Of course 3 times is still a lot of work but leaves you with layers, the 3 digit plus one are more homogeneous and the carbon will be burnt off or diffused across the metal.
With a tightly defined definition of the katana and wide one of the Zweihänder that can be true.
But that's by taking every two handed sword from Europe against a select sample of near identical swords. |
As I understand it, the steel in katanas was folded in order to hammer out the impurities and that the hammering and folding process can only remove so much steel, so folding it much more than three times isn’t worth it. Are you saying the myth comes from people confusing folds with layers? Also, are you saying that they folded 4 times?
As far as the Zweihänder, I think it is usually, but not always, defined as a German sword, The exact difference between a Zweihänder and other swords, like a great sword, is unclear. On the other hand, people use the word Katana to mean any Japanese sword. That is a good point about the narrower definition of the katana, though.
Wed 24 Aug, 2022 4:09 pm
Yes the folded a thousand times myth comes from them getting layers mixed up with folds.
How many times there folded depends on the goal, 8 is reportedly the norm but up to 16 is not unheard of, after that we're in to
going to 11.
Theres no practical benefits an at 20+ folds you have just homogeneous metal.
Not that a good pure homogeneous metal is bad for sword makeing but you've lost any advantage of patten welding.
Thu 25 Aug, 2022 11:24 pm
How many times there folded depends on the goal, 8 is reportedly the norm but up to 16 is not unheard of, after that we're in to going to 11.
Not that a good pure homogeneous metal is bad for sword makeing but you've lost any advantage of patten welding. |
Thanks. So we can consider number 4 fact checked as incorrect. Number 5 as true, but dubious and subjective. It is unclear if the meme author really means by katanas or Zweihänder. Also, looking at the wikipedia article on katanas, there are words for a lot of types of variations, but the pictures of the swords all look alike to a layman (me). One can say the same about a lot of European swords too.
I am going to add that I fact-checked 1, according to Wikipedia: Emperor Suzaku was born in 921 and the Koto design is dated to about 900. Koto is more the period than the sword type, which is the katana. The katana developed out of the tachi, so, it wasn’t if a totally new design was made, and tachis were still made and in use. Suzaku was also made emperor at 8, abdicated 16 years later and died at 30. The meme shows a poor understanding of Japanese government at the time. It was then common for emperors to abdicate, and even if they weren't minors, the regents had most of the power. The imperial office was mainly religious and ceremonial, and in fact, the Emperor was kept busy so that he wouldn’t get involved in politics. That explains why they abdicated. So it is unlikely that he was involved in sword making, and if he was, he wouldn’t have been able to arbitrarily dictate that no other sword type was made. Feudal Japan was not some centralized totalitarian government, and the sword industry was divided among the provinces and different so-called schools. I wouldn’t say that 1 and 2 and totally disproven, but it seems very doubtful.
As far as 3. I have yet to see a crossguard on a Japanese weapon, but double-edged swords were made after the 900s, although used exclusively as a votive offering, Tanto however are straight and Yari have straight double-edged blades.
Thinking about the crossguard, I think that another signature aspect of Japanese swords is overlooked, the long grip. A katana is about the same size as an arming sword, but has a grip long enough to generously accommodate two hands. I wonder if this creates more space that along with technique makes up for the small guard size. A similar guard is sometimes used on poleaxes, but one doesn’t always put one’s hand tight against the guard.
As far as 7. I was able to find out that Zweihänder tend to weigh between 5-7lbs, which is more than double a katana. So this is false.
Fri 26 Aug, 2022 12:39 am
Yikes, yeah this meme is definitely something. So on a few things that are definitely wrong. First is the whole all Japanese weapons were some variant of either the tachi or katana is pretty much just wrong. While their sword designs don't have as dramatic differences as European counterparts the polearms particularly the different designs of yari(spears) are fairly diverse. As to hand protection, everyone thinks of the edo period tsuba (disk guard) as the primary style for Japanese swords which makes sense since they are by far the most common and beautiful pieces of craftsmanship, but it is important to remember that the Edo period was a time of piece and the most common purpose of the tsuba was as basically sword jewelry. If you look at tsuba from earlier periods where warfare was actually common you find the tsuba are much larger, usually made of iron, and less decorative. These tsuba while much more protective were a bit of a pain in the ass to wear though so once actual combat was rare enough the tsuba shrank to make wearing a sword much more comfortable. (This is actually something we see all over the world as well with sword guard designs)
As to the whole "law" thing yeah that's just B.S. the emperor while technically as the head of state of Japan could make a decree and in theory it would have to followed, in practice very rarely did the imperial court have any real power. Depending on the period once you left the capital what ever the emperor said was basically ignored or if it was particularly offensive to the real political powers of the daimyo or shogun they replaced the emperor with someone more agreeable.
One last point then I'm done. Most people get stuck on the idea that the Japanese stuck with the same general sword designs with only minor changes out of conservativism and or obsession but that really doesn't track with history. People forget how fast and efficiently the Japanese adopted guns. Before the Edo period (basically 1600) Japan had a pretty thriving firearms production. Once the Portuguese introduced the first firearm they quickly went from solely importing they to producing their own. So while the sword doesn't change dramatically I don't think it's because of tradition or anything but most likely it was just simply the most practical design for their needs at the time.
Mon 29 Aug, 2022 1:57 am
| R. Kolick wrote: |
One last point then I'm done. Most people get stuck on the idea that the Japanese stuck with the same general sword designs with only minor changes out of conservativism and or obsession but that really doesn't track with history. People forget how fast and efficiently the Japanese adopted guns. Before the Edo period (basically 1600) Japan had a pretty thriving firearms production. Once the Portuguese introduced the first firearm they quickly went from solely importing they to producing their own. So while the sword doesn't change dramatically I don't think it's because of tradition or anything but most likely it was just simply the most practical design for their needs at the time. |
That is a good point with the disk guard, do you know how big they were? If they were big enough, they might actually provide more protection than a cross guard.
Did the Emperor really have the power to make decrees that were then ignored? I read that under the Fujiwara regents, the Emperor was kept so busy with ceremonial duties that he didn’t have time for politics. That, and the emperors were often had Fujiwara mothers and were minors. Emperor Suzaku´s father did rule for a time as an adult without a regent, though. Later Emperor Go-Sanjō (1068 – 1073) is said to have ruled directly, although there was an adult regent during his reign. I can’t find anything about how laws were formally made in the Heian period.
As far as the influence of guns, the Portuguese introduced them in 1543. However, this meme deals mostly with the time period from 900 to 1500s (the time that the law is supposed to be in effect). The is about 600 years of a supposed lack of change as well as a lack of variety. Of course, there was change and some variety. The features that the meme mentions that varied with the Zweihänder were: blade length, tip shapes, cross-guard shapes, and hilt lengths. There were certainly variety in the length of both blades and hilts in Japanese swords, and the disk guards also have variety of a kind. There were also improvements in forging. However, the Japanese used predominately single edged curved swords of a particular type, whereas the Europeans used not only straight double-edged swords of a particular type, but also a variety of other weapons, such as falchions. I think that can not really be explained by firearms.
Posts: 958 Location: Austria
Mon 29 Aug, 2022 11:37 am
A good rule in life is that the person making a claim is obliged to back it, the audience is not obliged to disprove it.
If you showed a Japanese person a collection of European swords from say 1200 BCE to 700 BCE, or 500 CE to 1000 CE, I think they might well say "for hundreds of years European swords were just variations on a theme." There were periods when European bladesmiths and cutlers were very creative, and periods when they were conservative.
Tue 30 Aug, 2022 5:58 am
| Mark Millman wrote: |
Dear Ryan S.,
I hope this proves helpful.
Best,
Mark Millman |
Very much, thank you.
Thu 01 Sep, 2022 8:00 am
Mark Millman summed it up perfectly. Not much I feel I can expand on as answers. One thing I think is good advice when trying to study Japanese history (or any east Asian history for that matter) is that the title of emperor theoretically has unlimited political power in practice that's really not true (just like with the HRE) the imperial family was fairly large and as long as you were generally a male in the main branch you were eligible to inherit. (Generally father to son but not always) so as long as the actual ruling faction prefaced everything as being for the emperor or in his name and paid lip service to the imperial throne you would be legitimate but because of the way the succession worked you could easily place a pliable candidate on the throne, and most of the smart emperors knew that while they were theoretically the one in charge they also knew who held the real power.
Off politics and back to swords, we actually do see evolution in Japanese swords between the 1000 and 1500s it just isn't as cosmetic as the changes in European swords.
Cross-section, curvature (both amount and location), tip shape, and length are all things that changed noticably in there swords that they can be used to date them fairly accurately. So while the changes weren't as cosmeticly dramatic as in European swords they were still changing and adapting to the period they were made in
Thu 01 Sep, 2022 9:47 pm
| R. Kolick wrote: |
Off politics and back to swords, we actually do see evolution in Japanese swords between the 1000 and 1500s it just isn't as cosmetic as the changes in European swords. Cross-section, curvature (both amount and location), tip shape, and length are all things that changed noticably in there swords that they can be used to date them fairly accurately. So while the changes weren't as cosmeticly dramatic as in European swords they were still changing and adapting to the period they were made in |
I don’t know that much about the Japanese Emperor or how the government actually functioned, which is why I am curious, how it worked. However, I do know that the Holy Roman Emperor did not have theoretically the power to do anything. European monarchs were theoretically bound by the law and couldn’t rule by decree. Sometimes they overstepped what they were allowed to do, often they committed crimes and got away with it. However, they couldn’t raise taxes without the approval of some sort of body, be it the estates, parliament, or the imperial diet. This is just detail stuff, like if there was the equivalent of royal assent in Japan. I think we agree with the big picture stuff, that the Japanese Emperor wouldn't have been able to restrict sword design to one type on a whim, and an Emperor with enough political savvy to get laws passed probably wouldn’t have wasted his political capital on something so trivial. Anyway, if you don’t know the details, then that is okay, I don’t either.
As far as sword design variation, the idea I got from the text of the Wikipedia article is that there were constant changes and variations, but the pictures look all alike. However, the pictures don’t really fit the text, and there really isn’t a graphic like the Oakshott typography that shows the differences. Add to that the fact that the text is full of Japanese terms whose meanings are not immediately clear, and there are three overlapping systems of classification, and the result is that it is hard to understand what exactly the differences are. Even though if I fully understood the differences between the variations, I don’t think I could objectively evaluate the degree of variation between Zweihänder and Katana. Therefore, unless someone has more information, then I would rate the statement that “Katanas have less variation than Zweihänder” as not based in fact.
Here is the best resource on variation on Japanese swords that I have found, at least for a beginner: https://weblog.tozando.com/sori-the-curve-that-captures-the-sharpness-and-beauty-of-the-japanese-sword/ It has, in my opinion, the advantage of explaining design changes with practical reasons. There are also articles on the different types of fullers as well as hamon.
Interestingly, the traditional origin story of the Japanese single edged curved sword was that it was invented by Amakuni and his son around 700 AD. Both were swordsmiths and the part of the story that I find most illuminating was that the swords were better compared to the old design, in that they didn’t break. Since the curve comes from the tempering process, then perhaps the curve was originally incidental to what was mainly an attempt to produce a more durable sword.
You
cannot post new topics in this forum
You
cannot reply to topics in this forum
You
cannot edit your posts in this forum
You
cannot delete your posts in this forum
You
cannot vote in polls in this forum
You
cannot attach files in this forum
You
can download files in this forum
