Forum Index > Historical Arms Talk > Bearded axe and Warhammer Reply to topic
Toni R.
PostPosted: Thu 12 Apr, 2007 12:21 am    Post subject: Bearded axe and Warhammer         Reply with quote
Hello again..
Here are couple of pieces I made about a year ago, just wanted to share them with you other enthusiasts
So, the bearded axe is trying to raise some viking spirit with its looks. It is 66cm long, and weighs about one kilogram. I took a little shortcut in the making process I bought a cheap, LARGE axe(I think it was about 8€) and modified it into this. I used angle grinder to cut the shape, and belt sander to clean the surface, since it was covered with paint. The handle was also lacquered, and I sanded it clean. After sanding I dyed and waxed it. The blade quality is not much to talk about. While cutting it to new shape, I revealed some hollow points that were inside the blade Guess it was welded into one piece where ever mountainside it was made...
And on we go with the warhammer...It´s 73,5cm long and the weight is maybe a bit over one kilogram(haven´t measured). The "blade" is milled and sanded from mild steel. The langets(or what do you call them?) are also mild steel, and made of one piece, bended over the "blade". "blade" is riveted into its place through the langets. The langets are then riveted through the handle with four rivets, so the structure is quite durable. Handle is dyed ashwood. I have thought if that handle should have been a bit longer, since the front part is quite heavy...
I had the advantage to use proper tools making these things at my school workshop, so it didn´t take too long to finish them. I would eagerly want to test especially the warhammer with an old car or something as much as fun Laughing Out Loud
 Attachment: 84.44 KB
axe [ Download ]
 Attachment: 84.15 KB
axe blade [ Download ]
 Attachment: 81.93 KB
warhammer [ Download ]
 Attachment: 89.13 KB
warhammer close-up [ Download ]
Nick Winley
Reading list: 12 books
PostPosted: Thu 12 Apr, 2007 12:43 am    Post subject:         Reply with quote
Very nice!
Does the shaft of the warhammer extend through the head or is it just butted on top? How was it done historically?
Nick
Toni R.
PostPosted: Thu 12 Apr, 2007 1:03 am    Post subject:         Reply with quote
To Nick:
The shaft doesn´t go through the head, it´s just butted on top with the rivet going through. I thought about making a spike on the top, and it might have been a good idea to then install that spike through the head and into the shaft. Didn´t do it after all. The way I made it, the construction is quite strong, and there is not very much distress pointed to the shaft. The head also keeps firmly on its place.
I´m not quite sure, is this historically how accurate, but I remember that I have seen something like this...anyway, it works just fine Wink
Etienne Hamel
PostPosted: Sat 28 Apr, 2007 2:13 pm    Post subject:         Reply with quote
The axe came out very good congratulation. I love it.
But you said you just bought a wood axe and reshape it into a beard axe?
Joe Fults
PostPosted: Sat 28 Apr, 2007 6:11 pm    Post subject:         Reply with quote
Nice done it yourself projects.
Michael Douglas
PostPosted: Mon 30 Apr, 2007 10:06 am    Post subject:         Reply with quote
Cosidering your raw materials,
that bearded axe is beautiful! Congratulations. (I should know, I've seen many awful bearded axe abominations)
If you make the edge very sharp and reduce the edge-shoulder you can hold it 'inside' the beard and get a great planing action.
As for the warhammer I really like the simple head, I'd just shape the sides of the langets? to make them more handmade-looking, or even tapered from top to bottom.
Great work.
View user's profile
Toni R.
PostPosted: Tue 01 May, 2007 12:56 am    Post subject:         Reply with quote
Thanks.
To Etienne: Yes, it was a large wood axe that I reshaped with anglegrinder.
To Michael: Thanks for the tips. I also think that I could have removed some more material from the axe and make it a bit more lighter. And it´s true that the langets on the warhammer might have needed some more shaping. Guess I wanted to finish the piece as quickly as possible...also wanted to keep it simple. The hammer is quite heavy for it´s size(I think), so the shaping of the langets might have reduced the weight also. The weight gives a good swing and powerful hit, but it´s not too quick to handle.
Etienne Hamel
PostPosted: Tue 01 May, 2007 6:53 am    Post subject:         Reply with quote
Can you give me the measurements of the axe head? (lenght,width and weight)
Toni R.
PostPosted: Wed 02 May, 2007 4:59 am    Post subject:         Reply with quote
I put the dimensions to the picture attached. Hope it helps. I didn't have anything at hand to measure the weight so it will have to wait. I would call it light rather than heavy, if it helps Wink
Feel free to ask if you need more measures.
-T
 Attachment: 91.75 KB
axe head measurements [ Download ]
Etienne Hamel
PostPosted: Wed 02 May, 2007 2:34 pm    Post subject:         Reply with quote
thanks it'll help if i want to do some competition with your axe and my future creation! Wink
J. Pav
PostPosted: Wed 02 May, 2007 6:13 pm    Post subject:         Reply with quote
I am COMPLETELY in love with that axe.
Everything about it screams 'PERFECT' to my sense of aesthetics.
Toni R.
PostPosted: Thu 03 May, 2007 3:00 am    Post subject:         Reply with quote
Well...I'm overwhelmed with pride Big Grin
Glad you like it.
-T
Michael Mercier
PostPosted: Thu 03 May, 2007 11:50 am    Post subject:         Reply with quote
That axe is a great idea. I might have to try that myself. It looks really wonderful. Very smooth lines. You must have spent a lot of time on the grinder!
Mike
Toni R.
PostPosted: Thu 03 May, 2007 12:01 pm    Post subject:         Reply with quote
thanks again.
Actually it was quite easy to work with, and took maybe about 2-4 hours to finish. I grinded the basic form with a large angle grinder, and used a belt sanding machine to smooth the lines. When you do some work with an angle grinder and get familiar with it, it's actually very handy to work with.
-T
John H.
PostPosted: Sun 13 May, 2007 1:55 pm    Post subject:         Reply with quote
^AGREED.^
I never would've guessed that it began as a "modern" axe-head.
Out of curiosity, what overall length did you make the handle? It isn't obvious in the photos, & I don't recall seeing it in the thread previously.
Thanks,
John
Toni R.
PostPosted: Mon 14 May, 2007 12:30 am    Post subject:         Reply with quote
Thanks,
John
Thanks again.
The overall length of the axe is 66cm, as I said in the first post Wink
-T
John H.
PostPosted: Sun 20 May, 2007 11:37 am    Post subject:         Reply with quote
Toni R. wrote:
...as I said in the first post Wink
Oops, reading comprehension is my friend. Blush Big Grin
Thanks anyway, I think I might try to have a go at a project like this. We'll see what happens...
