Forum Index > Historical Arms Talk > 6 in 1 maille Reply to topic
Jan J. Gahy
PostPosted: Thu 29 Mar, 2012 3:22 am    Post subject: 6 in 1 maille         Reply with quote
6 in 1 pattern maille or as we call it in Slovakia "the kings pattern".
Does anyone have this kind of pattern in full maille? Is there any historical evidence of this kind of maille or using this pattern? I once heard that these pattern could be used for maille coif because of its density of the rings for better head protection.
Thanks for answer in advance.
Randall Moffett
PostPosted: Thu 29 Mar, 2012 4:33 am    Post subject:         Reply with quote
There is a mail matle at the British Museum which has some 6 in 1 parts.
PostPosted: Thu 29 Mar, 2012 12:38 pm    Post subject:         Reply with quote
I vaguely recall a middle eastern haubergeon that was made entirely of 6-in-1. I trusted the source at the time but can't remember it atm.
Eric S
Reading list: 8 books
PostPosted: Thu 29 Mar, 2012 3:22 pm    Post subject:         Reply with quote
The Japanese used 6 in 1 mail.
PostPosted: Thu 29 Mar, 2012 7:05 pm    Post subject:         Reply with quote
That's not what is referred to as "kings pattern". The weave in question looks exactly like 4-in-1 except when up close.
Glen A Cleeton
PostPosted: Thu 29 Mar, 2012 8:48 pm    Post subject:         Reply with quote
http://artofchainmail.com/patterns/european/basic1in6.html
William P
PostPosted: Fri 30 Mar, 2012 12:28 am    Post subject:         Reply with quote
i made an experimental batch of 6 in one ouf of quite large key rings and the 6 in 1 had some issues with flexibility comapred to the 4 in one, yes im aware that key rings big enough to go onto ones inex finger, nickel plated no less, would replicate much smaller diameter historical maile.
so i could imagine someone making a maile haubers that has sections that are of a 6 in one weave, like the shoulders or maybe the elbow, or the back of the hands/ wrist,
in the case of byzantine, russian and persian helmets with full face maile curtains, a bit moresolid maile wouldnt go amiss.
(cataphract helmets, i forget which era, often had at LEAST a double maile screen, some had three layers (at this point, that much maile will start behaving like solid plate, almost)
but not a WHOLE hauberk/haubergon of maile, however a 6 in 1 byrnie i.e a shirt of maile would be managable, and a short, almost a vest of 6 in one maile over a normal 4 in one hauberk would maybe provide the extra protection of vital points one would need , but not all the time.
PostPosted: Fri 30 Mar, 2012 1:28 am    Post subject:         Reply with quote
I made a whole haubergeon out of 6-in-1. I had to use finer wire than I would have with 4-in-1 but there were no flexibility issues at all.
PostPosted: Fri 30 Mar, 2012 1:32 am    Post subject:         Reply with quote
The above photo is a good example of how crazy you have to get with small diameters and multiple links for butted mail to provide any kind of protection against points.
Jan J. Gahy
PostPosted: Fri 30 Mar, 2012 8:37 am    Post subject:         Reply with quote
Thanks for answers
That Japanese armour looks amazing, maybe I ll try to do something similar. Happy I saw those triangular patterns before but not with multiple rings.
About 6 in 1 pattern: I was recently trying this pattern and i was surprised by its thickness and flexibility, thats why i was asking question about historical evidences of this pattern because Im thinking about making the whole shirt from it. Here are photos of what i did (those are only butted rings) and comparison with 4 in 1 pattern. (sorry for mobile phone quality:/)
Dan: would you please post picture of that 6 in 1 haubergeon? Im really curious how it looks like when its done.
 Attachment: 216.46 KB
 Attachment: 216.08 KB
comparison [ Download ]
PostPosted: Fri 30 Mar, 2012 12:31 pm    Post subject:         Reply with quote
I sold my entire armour collection a few years ago to pay for the Dendra Panoply. I'm slowly building up my collection again but most of my replicas and reconstructions are from the Bronze Age now.
Adam Bohnstengel
PostPosted: Sun 01 Apr, 2012 8:33 am    Post subject:         Reply with quote
What was the diameter that you used? Was it riveted, or butted?
Violence is the supreme authority from which all other authority is derived.
Johan Gemvik
PostPosted: Sun 01 Apr, 2012 12:46 pm    Post subject:         Reply with quote
I've seen a few museum piece neck protectors made with 6 in 1 pattern. Never seen an entire maille in 6 in 1 though, but that doesn't mean they never existed or isn't out there in some museum.
Every tailored maille woudl have some small areas with it as expanding and shrinking the weave results in some rings collecting 6 or even as much as 8 rings.
I know from experimenting a lot with butted 6 in 1 mailles some 15-20 years ago that it got heavier and a little less flexible. Not unmanageable, but they are a bit harder to tailor though.
PostPosted: Sun 01 Apr, 2012 1:06 pm    Post subject:         Reply with quote
A FEW? Which ones? As far as I am aware the BM example is the only one that has been confirmed 6-in-1.
PostPosted: Sun 01 Apr, 2012 1:10 pm    Post subject:         Reply with quote
Diameter was c.10mm. Wire was 0.8-0.9mm. I made it from butted links. I wasn't interested in historical accuracy, I just wanted to see how the weave functioned and butted links was the quickest way to assemble a shirt. I've also made a collar from 6-in-1 that was almost rigid. So, just like 4-in-1, the amount of movement in the weave depends on the wire diameter and link size, not the type of weave used.
The question is whether 6-in-1 can provide better protection than 4-in-1 if the two samples are made with the same degree of flexibility. Keep in mind that 6-in-1 uses twice as many links as 4-in-1 so the weight should be doubled. However, if you want the same link size as 4-in-1 then you need to reduce the thickness of the wire so the final weight will not be doubled, but it will be heavier. Is that weight increase worth the additional protection?
Johan Gemvik
PostPosted: Sun 01 Apr, 2012 1:23 pm    Post subject:         Reply with quote
You're probably right and I may only have seen that one. Sorry to tease like that.
Randall Moffett
PostPosted: Sun 01 Apr, 2012 2:02 pm    Post subject:         Reply with quote
Dan,
I think Russ Mitchel found another example in Hungary of 6 in 1 mail. I thought I had pictures of what he posted but could not find it there or on the AA..
PostPosted: Sun 01 Apr, 2012 2:09 pm    Post subject:         Reply with quote
Is this the one from BM? I didn't know it's 6 in 1 when I saw it, I thought the rings are just thicker and maybe smaller in the upper part...
Julio Junco
PostPosted: Sun 01 Apr, 2012 3:58 pm    Post subject:         Reply with quote
I made 6 x 1 mail nine years ago. It was absolutely flexible, and more like weave, like real clothing.
It was 1'3 wire, stainless steel, piano wire. Really hard. And with 8-8'5 mm internal diameter.It weighs 9'8 kgs.
Not historic, but it was very very nice. And opaque, you don“t see nothing back of the mail.
Julio
 Attachment: 21.43 KB
Johan Gemvik
PostPosted: Mon 02 Apr, 2012 2:27 am    Post subject:         Reply with quote
That's not the one I was talking about at least. So maybe there are more than one out there.
The one I saw had one tounge at the front and straight edges on the sides and it wasn't gilded. I can't for the life of me remember where I saw it though.
