Forum Index > Historical Arms Talk > Danish Oakeshott Type XVIIIe swords (& other 2-handers). Reply to topic
This is a Spotlight Topic Go to page Previous  1, 2, 3, 4, 5, 6
Niels Just Rasmussen
Spotlight topics: 15
PostPosted: Fri 08 Jan, 2016 11:41 am    Post subject:         Reply with quote
Mike Ruhala wrote:
Niels Just Rasmussen wrote:
I'm just not certain that "volley fire" existed in Germanic warfare?! Neither to have groupings/bulks of archers OR to use long range incoming arrows. It seems that even at Agincourt 1415 arrows were used at fairly close range with a flat trajectory (Tobias Capwell). I think both Iron Age Germanic javelin throwers and archers are rather lightly clad fast moving skirmishers like the Roman Velites used in the republican army and the Thracian troops under Alexander the Great.
It may be that late in the Viking Age (900-1000 AD) with the big invasion forces you start to have more masses of archers, but the Viking Shield was actually changed to the Kite shield at Hastings in 1066.
So I agree that viking shield's must have some specific advantage reflecting a change in the battle weaponry, but I'm not certain it's primarily because of arrows.
It would be interesting if we could determine when massed units of archers began appearing on the central/northern European battlefield. Likewise it would be illuminating to figure out exactly when round shields became the dominant form among Germanic and Scandinavian warriors. Kite shields probably appeared decades before 1066 but if the Bayeux Tapestry is to be believed it's important to remember quite a few round shields are also depicted even if they are a minority.
Could it be response to increased use of axes?? I just toss forward a hypothesis here.
You see that Iron Age warriors have a general set of spear and shield, with the elites having swords. Then we (perhaps?) see from Late Iron Age the axe becoming a normal soldiers weapons with the shield and spear. Axes can hook weapons and shields (especially bearded axes), so maybe it is way harder to destabilize a person holding a round-shield than a rectangular one?
I wouldn't think so, it's not so hard to hook a round shield with an axe's bottom horn, it's sharp and metal so it'll tend to bite into the shield regardless of rim shape.
I haven't tried any reenactment so I don't know how well Viking shield actually can lock up in a shield wall. With the center group it is unstable from pressure on the sides, so are locking the shield together enough to withstand a hard charge?
Apparently the wider heavier viking shield appear later in the archaeological record than the smaller shields, so the shield wall seems to be a late development of the viking shield for greater amount of men on the battlefield and definitely a chance from semi-close formations to a tight formation in the later part of the viking age.
They did it so we know it worked but unfortunately the finer details of how they formed shield walls haven't been recorded as far as I know so the best we can do is just try it out for ourselves and see what appears to work the best. Consider a sample of three men standing shoulder to shoulder, the shield of the man in the middle is in front of the shields of the men to his left and right, kind of like this _--_. If that center man applies rearward pressure to his shield while the men to the sides apply forward pressure a surprisingly rigid structure will result. This doesn't even have to take a lot of muscular exertion to maintain, they can adjust their weight distribution in their fighting stance and essentially lean on each other. It works better with more men, like this _--_--_--_--_--_--_--_.--_--_--_, which may have something to do with why shield walls could break.
Classical inspiration during the Ottonian renaissance is very possible, but the classical weapons didn't have a cross-guard, so the gaddhjalt is a radical innovation as you say and must be something completely new? Where it happened is very hard to say, since "news" spread fast apparently.
Just to clarify it wasn't the weapons or martial arts that influenced later swordsmanship directly, it was philosophy. If you give two ignorant people sticks and tell them to fight the first thing they'll come up with is a very simple parry-riposte system. That has its use but is vulnerable to the next thing they'll figure out on their own, feints. From there some clever people will realize that under certain circumstances it's possible to attack and defend with the same action but that's about as far as it gets without a proper teacher. There are other ways to use time and space that aren't particularly intuitive but are critically important to Medieval and later fencing systems, even after you've had them explained to you and understand them it takes a lot of training to be able to actually use them. This stuff was somehow derived from Aristotle's teachings, I don't know all the history on that but apparently Book IV of his Physics plays an important role.
http://classics.mit.edu/Aristotle/physics.4.iv.html
The problems with skeletons is that they don't show soft tissue damage. So stabs in the stomach region can basically never be shown archaeologically.
The most immediately fatal target in the abdomen is the aorta, I don't see how it would likely be damaged without leaving marks on at least the spine. In any case we do have Viking Age evidence to consider. Google turned up the link below which provides several useful leads, hopefully it works for you.
https://books.google.com/books?id=Ha-8CgAAQBAJ&pg=PA37&lpg=PA37&dq=wounds+viking+skeleton&source=bl&ots=eFHsAUa1bB&sig=ViPTugiDQb-EgguLo7nwj5IrB4U&hl=en&sa=X&ved=0ahUKEwibr4fdj5fKAhVJGR4KHYnUBOw4ChDoAQgpMAQ#v=onepage&q=wounds%20viking%20skeleton&f=false
I have't seen any real evidence of massed use of archers in Northern Europe before the English started using them in great numbers from 1300 (?). It coincide with the development of very strong bows, so my gut feeling tells me that it's a new battlefield development.
About round shields from the Viking Ages we only have 1 fairly complete one from Denmark and then also a number of partial shields from Norway.
Earliest appearance?
Then from the Iron Age you have 2 round shield from Thorsbjerg Mose and that is a deposit from 200's AD, so perhaps these are the earliest round shields, though you have found round shield from the Nordic bronze age as well?
Thorsbjerg shields: https://en.wikipedia.org/wiki/Thorsberg_moor#/media/File:Thorsberg_Shields.jpg
A viking shield found at Trelleborg ringfort on Sjælland gives us a precise date of the 980's. It is 80 cm in diameter. The men stationed at Trelleborg was an army, so it's with all certainty a shield for battle and not for duels.
Article with picture in situ: http://www.kristeligt-dagblad.dk/danmark/ark%...ingeskjold
After preservation: https://wuhstry.files.wordpress.com/2015/12/capture-1.png
So axe is most likely not a reason for the change of shield shape.
Thanks for your shieldwall explanation - quite interesting!
So it is the Aristotelian scientific thinking that might revolutionize sword teachings at some point in the middle ages?
Could probably be true, but so hard to say when it began: Boethius Latin translations of Aristotle (for instance "The Catagories") had not been lost in the Western World and was available all through the middle ages and used in the Monastic and University teaching. The "quadrivium" was likely formulated and introduced by Boethius (480-524)!
Sorry for historic digression:
Especially the "Commentary on Aristotle's Metaphysics" by Ibn-Rushd/Averoes became important in the early 1200's, though it met a lot of opposition that almost crushed it.
Ibn-Rushd wrote to fight for Aristotelian philosophy against the anti-philosophical doctrine of Al-Ghazali, but totally lost the debate in the Islamic world as they never had any "Averoesians" since then (the important idea is the splitting of religious and philosophical thinking as two different entities), but became so famous in Western Europe he was simply known as "The Commentator".]
Funny enough one of the two leaders who fought for introducing the Averoesian/Aristotelian philosophy at the Paris University was another Boethius - this guy was Danish though: Boethius of Dacia latinized for "Bo af Danmark" [Denmark was commonly called Dacia in the middle ages if any Romanians get confused by that]. Accused of being "Averoesian" he had to flee Paris in 1277 with his philosophical-comrade-in-arms Siger of Brabrant as their movement was deemed heretical.
So the real take off for Averoesian/Aristotelian thought on a broader level is from early 1300's, when the English Franciscan friar William of Ockham/Occam (called Venerabilis Inceptor, “Venerable Beginner”) cuts the way with "Occam's razor" even today a fundamental of science like cladism of paleontology. Teachings of Ockham became the "Via Moderna" in conflict with Thomas Aquinas that became the "Via Antiqua" (Aquinas tried to fuse Aristotelian reason and faith together, which faith superior if in conflict with reason). Later a guy named Martin Luther studied "Via Moderna" and learned to split knowledge and faith into two separate compartments!
Germanic people had professional warriors (and also professional duelist according to the sagas) doing nothing else all their life at least from the Iron Age, many working for Romans then attacking Romans or other Germanic people.
I would think that the books starting to be published - I.33 as the first we know about from exactly around 1300 - might be from classical inspiration, but advanced fighting skills must have been taught for generations (just not put into any sophisticated more scientific system based on catagories - and that is the real revolution).
Whether fatal blows to the abdomen would give spinal injuries depends very much on angle - it would think many would have been dying fast or slowly over days from stomach wounds not giving any skeleton marks.
About the viking graves in England: The problem is that we can't be certain if it is actual battlefield wounds, or captured people massacred! [St. Brice Days massacre for instance]. Just when looking on the page you gave the link to:
The Oxford and Ridgeway Hill examples shows in my opinion massacre like injuries (probably extensive torture before final death). The Fishergate example from York is much better since you have varied types of injuries.
Last edited by Niels Just Rasmussen on Tue 12 Jan, 2016 1:11 pm; edited 1 time in total
Mark Lewis
PostPosted: Sat 09 Jan, 2016 9:35 am    Post subject:         Reply with quote
A fresco from Brönnestad, in Southern Sweden (formerly Danish territory), dated c. 1440, very clearly shows long-gripped swords in the hands of Herod and his soldiers. The flaring quillons match the distinctive Scandinavian group that Oakeshott identified as 'family K', and the blade shape seems very similar to D4850 in Copenhagen - long parallel edges, but with a pronounced triangular tip.
Large long-swords appear frequently in German art of the same period, but usually not quite of the exaggerated Danish proportions. This morning I came across the effigy of Ghese von Bibow, dated 1445, which shows the extra-long grip and curved cross so common among Scandinavian swords. Perhaps not coincidentally, the effigy is from the far North of Germany, in Mecklenburg on the Baltic coast.
Another German example of a particularly large sword, again from Mecklenburg, appears on the effigy of Wilhelm von Werle, d. 1436.
From just a little farther east, in Vorpommern, we find an example of a sword with the upturned quillons apparently common in Danish swords, but seemingly rare elsewhere. The correlation between the style and the Scandinavian-Baltic region seems quite strong.
Paul Morder, 1427.
Another example from Saxony-Anhalt, farther South, breaks the trend however.
Henning von den Roden, 1414.
PostPosted: Sat 09 Jan, 2016 1:06 pm    Post subject:         Reply with quote
Paul Morder, 1427.
Yeah the "Boringholm-style quillons" (Oakeshott family K) are appearing on Danish church paintings from possibly late 1300 well into 1500's so over 100 years. With some possibly turning into C-guard quillons like the Hinge Swords (D4445 and D4446)?
Blades on them changes through time and good spotting that D4850 in Copenhagen share the features of "long parallel edges with a pronounced triangular tip".
The two Mecklenburg examples looks what you would expect from a non-ricassoed Danish-Two-Hander.
Albrecht III of Mecklenburg was in fact Swedish King from 1364-1389 (until defeated by Danish Queen Margrethe I).
Being in the Baltic influences in weapons must have gone both ways.
The upturned quillon sword showing up in Vorpommern and Sachsen-Anhalt does show to a distribution center from Danish and Northern Germany and east into Modern Poland. These areas in the East were primarily settled by Saxons during the middle ages as far as I remember (Danes concentrated on Rügen).
I think the Saxony-Anhalt population were to some extend Saxons forced moved from their North German home (having borders with the Danes and the Wends) by Charlemagne and moved south. So probably didn't have much attachment and had no problem mass migrating away eastwards.
So it seems this style of quillons have a marked Danish/Saxony core based on what we know currently.
PostPosted: Tue 12 Jan, 2016 8:13 am    Post subject:         Reply with quote
Looking at some Danish epitaphs with two-handed swords.
Here is Henrik Friis til Ørlunde - written Hendrick Fris - (1496-1571) and his wife Margrethe Bild from Hesselager Kirke.
Nice two-handed sword with forward curving quillons (maybe C-guard like as the Hinge swords?) and a ball like pommel.
Source: http://www.gravstenogepitafier.dk/
Bigger size picture: http://fynhistorie.dis-danmark.dk/node/30572
So since he died in 1571, this must definitely be a depiction of the sword he carried in his youth 1520-30's?
Sadly his hands is placed so we can't see if it has a ricasso or not.
What cool armour he wears by the way!
The coat of arms of the "Friis af Hesselager" family:
Source: http://fynhistorie.dis-danmark.dk/node/30565
Here modernized:
Source: https://da.wikipedia.org/wiki/Friis_(adelssl%C3%A6gter)#Sl.C3.A6gten_Friis_fra_Hesselager
Henrik Friis was the brother of the more famous Johan Friis (1494-1570) who became the Chancellor of the post-Reformation Copenhagen University in 1537. He was also the Kings Chancellor and member of the Danish Rigsråd. Under King Frederik II he basically ruled the country as the King has little interest in politics.
Source: https://en.wikipedia.org/wiki/Johan_Friis
Last edited by Niels Just Rasmussen on Fri 15 Jan, 2016 9:56 am; edited 3 times in total
Per Lillelund Jensen
PostPosted: Tue 12 Jan, 2016 10:33 am    Post subject:         Reply with quote
The third sword is from Roskilde Cathedral found on the coffin of King Christian I in 1843. The grip had wood and brass-thread preserved when found and also a leather scabbard with an inside of "lærred" (weaved fabric) which had rusted onto the blade. Neither grip wood, brass nor scabbard was conserved.
Total Length: 133,5 cm
Pommel: 6 cm high, pear-shaped and facetted (gilded bronze)
Grip: 30 cm
Cross-guard: Gilded bronze. One end broken, The other end is "båndformet" (band-shaped ?) and bent forwards. Original length estimated at 15,7 cm.
Blade length: 97,5 cm [weak middle ridge]
Blade width: Max 6 cm
Ricasso: 17 cm [4-sided with a flat 2 cm wide fuller].
Stamped marks on both grip and ricasso.
Is on display in Roskilde Cathedral.
Niels i had a chance to examine and measure this sword last year, and the measurement i took does not match those by Ada Brunn Hoffmeyer.
PostPosted: Tue 12 Jan, 2016 10:43 am    Post subject:         Reply with quote
The sword is said to be 133,5cm long total. but in fact its 1292mm long in total. The grip is not 30cm long either but 220mm and 275mm including the pommel. The blade is 1005mm from tip to crossguard. The Blade is 35mm wide at the widest part just below the Ricasso and about 13mm thick in the center. The Ricasso is 18,5cm long and between 25-28mm wide and 10mm thick. The crossguard that is broken would originally have been about 158-160mm wide. the only measurements that actually matches Ada Brunns measurements.
regards
Per L
PostPosted: Tue 12 Jan, 2016 11:20 am    Post subject:         Reply with quote
Grip: 30 cm
regards
Per L
Hej Per.
Thanks a lot for your input.
So how is your opinion of its handling and balance?
So strange Ada Bruhn Hoffmeyer got the measurements that much wrong?
4 cm to long in total length.
Grip 2,5 cm to short (if she included grip+pommel)
Blade length 3 cm to short.
Blade width 2,5 cm to wide.
Ricasso 1,5 cm to short.
She only got the pommel 0,5 cm to long and is almost correct with the crossguard length.
Did she perhaps measure it "by eye" where it was hanging in the Roskilde Domkirke, as that is really sloppy work to be so off if you actually had the sword in your hand??
PostPosted: Tue 12 Jan, 2016 11:52 am    Post subject:         Reply with quote
Hi Niels
i did not exactly have it in my hand. the sword is mounted on a wooden plank that cannot be removed without great difficulty. And the plank is mounted about 5-5,5m above the floor. So i was standing on a tall ladder. And took measurements and notes and photos from that. Still i dont think my measurements is more than maybe a few mm of on the total length, not like Ada Brunn Hoffmeyers 40mm.
I think the sword could quite surely be dated to the mid 1460ties. And its quite tantalising to imagine that the sword was was worn and used by the King at either the battle of Harakker 1463 or Brunkeberg 1471. The king died in 1481 where the sword was placed on top of his casket.
Per L .
PostPosted: Tue 12 Jan, 2016 12:23 pm    Post subject:         Reply with quote
The closest comparison to the King sword in Roskilde i have been able to find in period art is the Lütjenburger altar dated 1467 in Schleswig-Holstein, Plön. The sword on the figure on the right bears a very strong resemblance with the kings sword, and pretty much shows how the sword would have looked like when in use. Also the sword on the left is of the same type but with a more gently curved crossguard.
Per L
 Attachment: 367.38 KB
 Attachment: 338.35 KB
-16063-1Group of guards under the cross. Piece of the Lütjenburger Altar. date1467.jpg
 Attachment: 314.13 KB
PostPosted: Tue 12 Jan, 2016 12:29 pm    Post subject:         Reply with quote
more photos of the king sword in Roskilde Cathedral.
Per
 Attachment: 294.93 KB
 Attachment: 353.49 KB
 Attachment: 380.45 KB
PostPosted: Tue 12 Jan, 2016 12:31 pm    Post subject:         Reply with quote
pommel
PostPosted: Tue 12 Jan, 2016 12:46 pm    Post subject:         Reply with quote
Great pictures Per. Thanks a lot for sharing them!
Yep that sword is really nailed firmly!
It shows that the preserved quillon of the sword of Christian I actually curves outwards like the Hinge Swords (so a weak C-guard).
That the other quillons are broken exactly at that curvature actually makes me think that originally the quillons were straight and then later they were curved into a C-guard, thus causing some metal fatigue?
Mark found that one of the Swedish swords had quillons that probably were bend secondarily.
So maybe my hypothesis that 'Danish-two-hander' -> 'C-guard swords' might not be totally far fetched.
Shame with the altar from St. Michaelis Kirche in Lütjenburg, that the two men both have the swords in their scabbards so we can't see the whether they have a ricasso or not!
They both have a rainguard, so that is significant!
PostPosted: Wed 13 Jan, 2016 9:25 am    Post subject:         Reply with quote
Hi Niels, i think its highly unlikely that the quillons was curved secondarily, as the king died in 1481 where the sword was put in his grave and therefore did not have so long a working life as many other swords and weapons.
Per
PostPosted: Wed 13 Jan, 2016 10:47 am    Post subject:         Reply with quote
Per
Hi Per.
What I meant by "secondarily" was perhaps bending according to new quillon fashion (as we have seen on one Swedish sword) and not secondarily in the case of wear/use.
Maybe the quillons were originally made with a slight C-guard curvature style (as with the Hinge Swords) and it is just broken in some kind of combat or training exercise?
PostPosted: Wed 13 Jan, 2016 11:16 am    Post subject:         Reply with quote
Making a research of Danish epitaphs and gravestones it becomes clear that most gravestones depicting men with weapons and armour are post 1550.
Up until sometime in the middle 1500's it seems to have been most common to have just the coat of arms, but no personal depictions.
Also those that survive from this early period are very very worn from people trampling on them for hundred of years, so especially the old drawings of Søren Abildgaard from the 1700's are critical for discerning details (though he doesn't always seem totally accurate).
So this gravestone is from Sankt Hans Kirke in Odense and depicts Gert Hartvigsen Bryske og Elsebe Kabel.
He was høvedsmand in Nykøbing Falster (1423) and later at Næsbyhoved and in the Danish "Rigsråd" from 1432.
He died in 1441.
So resting a big sword in one hand.
This is apparently the first fully developed plate armour we have a depiction of in Denmark. [though we have older effigies - like Junker Christoffer in Roskilde Domkirke from ~1363]
Precisely in 1441 the peasants north of the Limfjord in Jutland went into revolt under their leader - the nobleman Henrik Tagesen Reventlow, who actually ordered the rebels into a Hussite wagon defense tactics, but was smashed by Danish King Christoffer III of Bavaria. The King apparently knew how to counter this technique and it is speculated that the King's knights stormed the wagon defenses on foot.
Apparently the people from Mors started fleeing, then the people from Thy, but the people from Vendsyssel fought on to the bitter end refusing to flee. Such things still matter up there......
So found from Jetsmark Kirke in Hvetbo Herred in Vendsyssel this church painting of apparently a local guy (nobleman? since he actually have spurs on) who refuses to acknowledge that the viking age is supposed to be over and still retains an excellent beard Laughing Out Loud
He has just the most amazing overkill of weaponry ready. It is precisely dated 1474, so 30 years after the rebellion and in 1534 under Skipper Clement the Vendsyssel people would make their most famous rebellion!
But for our discussion the sword is interesting! Looks also like Hinge-style-quillons and has a rainguard!
 Attachment: 164.79 KB
"Need bigger weapons"?
Jetsmark Kirke. Dated 1474.
Source: http://natmus.dk/salg-og-ydelser/museumsfaglige-ydelser/kirker-og-kirkegaarde/kalkmalerier-i-danske-kirker/
PostPosted: Fri 15 Jan, 2016 10:24 am    Post subject:         Reply with quote
Same family, same armour, same sword from Hesselager Kirke? Answer is NO to second and third.
Epitaph of Henrik Friis (1496-1571) had this armour and sword I showed before on this thread:
Epitaph of his son Jesper Friis (1539-1561), whom drowned in "Lunde Mølledam" just 8 days after his sister Maren Friis (1545-1561 - on the right) had died! What a family tragedy!
Source: http://www.livinghistory.dk/
Notice that the two swords have different pommels. A bit more ball-shaped for Henrik Friis, while the sword of Henrik Friis has a more sharply angular pommel.
Also the armour varies in the collar. Henrik Friis has an armour with a collar providing neck protection, while Henrik Friis has a collar proving protection for neck and both sides.
Sadly even Jesper Friis has a hand placed, so you can't discern whether the sword has a ricasso or not.
The similarity between sword and armour is surprisingly great, so it actually took me some time to realized they were not identical. Maybe both sword and armour were ordered by both father and son at the same time from the same place?
PostPosted: Sun 06 Mar, 2016 7:15 am    Post subject:         Reply with quote
A late Renaissance church painting from Gudum Kirke in Northern Jutland of the battle between David and Goliath shows a huge Goliath with a great two-handed sword ["curving" to fit the composition]
The painting is dated 1550-1560.
One of the quillons looks "Branch-like".
In the other hand Goliath holds a very peculiar pole weapon - ends in a huge broad spear with an axehead and spike under it.
 Attachment: 159.16 KB
Goliath with two-hander.
Gudom Kirke - dated 1550-1560.
Page 6 of 6 Reply to topic
Go to page Previous  1, 2, 3, 4, 5, 6 All times are GMT - 8 Hours
