Craig Peters
Peter Spätling
Posted: Sun 12 Jun, 2016 7:16 am Post subject: |
are you sure you posted the right picture? The first one looks clearly to be maille.
Btw. look at that nice kattle hat on the second picture! Also note the great helm as well as the poleyns!
Edit: Did you mean this?
Mart Shearer
Posted: Sun 12 Jun, 2016 7:32 am Post subject: |
I presume the inquiry concerns the "panzerhose" in several other miniatures.
http://manuscriptminiatures.com/4080/13075/
http://manuscriptminiatures.com/4080/13076/
The construction seems to be like the later jacks of plate, with iron plates or perhaps baleen plaques sewn between layers of fabric in a running bond ("brick") pattern. It's also possible that this could be jazerant work, with mail and padding sewn between layers of fabric. Contemporary inventory records and regulations describe both types of construction.
Craig Peters
Posted: Sun 12 Jun, 2016 8:28 am Post subject: |
| Peter Spätling wrote: | are you sure you posted the right picture? The first one looks clearly to be maille.
Edit: Did you mean this? |
Peter and Mart,
Yes, those are the correct images. Thanks.
Mario M.
Posted: Sun 12 Jun, 2016 9:46 am Post subject: |
"Panzerhosen"
These examples are from a later date and apparently no longer exist because they did not survive the bombings of the second World War;
“The stream of Time, irresistible, ever moving, carries off and bears away all things that come to birth and plunges them into utter darkness...Nevertheless, the science of History is a great bulwark against this stream of Time; in a way it checks this irresistible flood, it holds in a tight grasp whatever it can seize floating on the surface and will not allow it to slip away into the depths of Oblivion." - Anna Comnena
