Forum Index > Historical Arms Talk > How thick should basket hilt bars be? Reply to topic
Dan D'Silva
PostPosted: Mon 30 Sep, 2024 4:06 pm    Post subject: How thick should basket hilt bars be?         Reply with quote
I've got this Deepeeka "English half-basket hanger" (actually a short Walloon sword) and I've been pondering replacing the bars to make it a sort of Scottish half-basket hilt -- i.e. some bars to add a degree of hand protection and make it look Scottishish, but not change the weight or balance too much. If I can find a welder, I could make the bars myself and send it off for assembly.
Are there any measurements available for the historical range of the bars' thickness? I can get 1/8-inch bar stock from any local hardware store, but I feel pretty sure that'd be overkill, and maybe it would be better to look for 12ga or even 14ga.
 Attachment: 451.03 KB
Chris Dayton
PostPosted: Wed 02 Oct, 2024 8:37 pm    Post subject: Basket bar thickness         Reply with quote
I once owned this exact basket hilt and some of the thicker basket bars were about 1/8" thick. I don't have it anymore so can't measure but that's my recollection. Hope that helps.
https://sbg-sword-forum.forums.net/thread/54967/antique-scottish-basket-hilt-broadsword
Dan D'Silva
PostPosted: Thu 03 Oct, 2024 1:06 pm    Post subject:         Reply with quote
Thanks, that does help. So we can consider 1/8-inch bars as being at least within the right range, if (maybe) at the upper end.
Leo Todeschini
PostPosted: Sat 05 Oct, 2024 2:33 pm    Post subject:         Reply with quote
I don't know from absolute knowledge, but from my feels for materials as a maker, if you made the hilt 2mm thick, it would be enough.
www.todsworkshop.com
www.todcutler.com
Dan D'Silva
PostPosted: Mon 07 Oct, 2024 6:51 pm    Post subject:         Reply with quote
That also sounds good. I'm searching right now, depending on the cost of shipping (since it looks like most bar stock measured in millimeters is retailed outside the U.S.), I may wind up with 3/32-inch, or 12ga sheet if I'm feeling confident in my ability to cut and grind the edges good and straight.
