Forum Index > Historical Arms Talk > Another DIY Rondel DaggerDIY Project Reply to topic
PostPosted: Thu 01 Dec, 2005 11:17 am    Post subject: Another DIY Rondel Dagger         Reply with quote
This piece is intended to represent a common German soldier's rondel dagger (Scheibendolch) of ca. 1510. Two examples depicted by Albrecht Dürer in woodcuts dated 1510 served as inspiration (see images below). Mine combines elements of both, but is in some ways speculative because the illustrations don't show details of the orignals' blades. They appear to be relatively broad and of flattened diamond section, though.
Components for my project included an 8" Arkansas Toothpick blade from Atlanta Cutlery (approx. $12), two large washers from Lowes, poplar for the grip, chamois for the grip cover (no cord underwrap-I've found that a temporary cord overwrap during drying gives the neatest effect), and a modified wing nut for the pommel nut. That's it. Less than $20 in parts.
I assembled the piece with JB Weld, slipped on the modified wingnut and cold-peened the tang before the JB Weld set. Of course, it was much more work than that–carving, filing, wrapping, polishing, sanding, etc.
I'm not thrilled with my freehand shaping of the grip (a concave cylindrical taper is much more challenging than a straight taper unless you have a lathe, and I don't have one). The textured grip wrap is speculative and probably not correct, but I think it looks nice and improves the feel of the weapon (the horizontal lines on the grip in the first of the illustrations below don't suggest a wrap. Rather, I think they're just engraving lines to indicate the shape of the object). I switched lower rondels at the last minute and did a sloppy job of filing the replacement, so it doesn't quite sit flush with the blade as planned. The edges of the peen split slightly (another lesson learned), but I'm not unhappy with the result. This is supposed to be a common soldier's weapon, after all. The finished piece feels very comfortable, tight and strong, and the proportions seem about right, judging from the Dürer woodcuts. It looks kind of pitiful compared to Risto's recent creation, but I'm still learning.
 Attachment: 98.04 KB
 Attachment: 84.11 KB
 Attachment: 50.3 KB
 Attachment: 100.05 KB
 Attachment: 103.98 KB
Russ Ellis
PostPosted: Thu 01 Dec, 2005 11:27 am    Post subject: Re: Another DIY Rondel         Reply with quote
Hey Sean... sounds great but is there a picture here somewhere that I'm not seeing?
TRITONWORKS Custom Scabbards
PostPosted: Thu 01 Dec, 2005 11:30 am    Post subject:         Reply with quote
Sorry about that, Russ! You caught me just as I was tweaking the photos. They should all show now. I thought about you while making this piece because I was also thinking about whether or not to make a sheath as well. Might still do it.
Kirk Lee Spencer
Spotlight topics: 6
PostPosted: Thu 01 Dec, 2005 12:17 pm    Post subject:         Reply with quote
very nice work Sean!
I really like the overall design... It really flows together.
ks
Two swords
Lit in Eden’s flame
One of iron and one of ink
To place within a bloody hand
One of God or one of man
Our souls to one of
Two eternities
Russ Ellis
PostPosted: Thu 01 Dec, 2005 12:23 pm    Post subject:         Reply with quote
Ahh there we go! Nice job there Sean. If you woudn't have fessed up about the components no one would have ever believed it. Happy I've got my own little project to work on this weekend... Wink
John Cooksey
PostPosted: Thu 01 Dec, 2005 12:30 pm    Post subject:         Reply with quote
Sweet!!!
That is very, very cool.
And, IMO, very much "in the spirit" of making do with whatcha got.
Glen A Cleeton
PostPosted: Thu 01 Dec, 2005 12:31 pm    Post subject:         Reply with quote
Looks great. A simple workaround for small lathe work could have been a carraige bolt and nut. Long enough that the threads can chuck in a drill. Small stuff can be done, paper in one hand, drill in the other but you can clamp the drill down.
With enough shop space, a small spring pole lathe could be slapped together pretty quickly.
GC
PostPosted: Thu 01 Dec, 2005 12:46 pm    Post subject:         Reply with quote
GC
Thanks for the positive feedback, folks!
Hmmm...I considered setting up a spring pole lathe but decided it would be too much hassle. Although I also considered and dismissed rigging up something relatively complicated with a drill, I didn't occur to me to simply hold the drill and use coarse paper to do the rough shaping. That's a very interesting and simple idea! There's a Roman spatha on my project list, so maybe I'll employ some technology for the grip. Thanks for the tip!
PostPosted: Thu 01 Dec, 2005 12:47 pm    Post subject:         Reply with quote
Is it long and pointy?
Wolfgang Armbruster
PostPosted: Thu 01 Dec, 2005 12:58 pm    Post subject:         Reply with quote
This one looks great, the blade seems be quite thick and durable.
The woodcuts are amazing as well. Do you know where I can get the full versions? Happy
The upper one appears to be by Dürer. And I thought I know all his works Wink
PostPosted: Thu 01 Dec, 2005 1:32 pm    Post subject:         Reply with quote
Both of these illustrations are by Dürer and can be found in The Complete Woodcuts of Albrecht Dürer, which is only about $13 USD. Wolfgang can get in Germany by following this link: http://www.amazon.de/exec/obidos/ASIN/0486210...63-1431741
Americans should get it through the myArmoury site by clicking here: http://www.myArmoury.com/books/item.php?ASIN=0486210979.
I have found this book to be a goldmine of visual information about German arms and armour of the late 15th/early 16th century. The artist was very familiar with the martial arts, so I have extra confidence in the accuracy of his depictions. The reproductions in this Dover Book are bright, crisp and copyright-free! I darkened the samples here to highlight the dagger.
 Attachment: 78.71 KB
Bill Grandy
Reading list: 43 books
PostPosted: Thu 01 Dec, 2005 1:39 pm    Post subject:         Reply with quote
Very nice job, Sean! The hilt work looks very nice. The blade looks a little "fat" compared to most rondel daggers I've seen, but I also understand that you're working with what's available. Have you seen any examples of originals with less acute tips such as with the Atlanta cutlery blade?
HistoricalHandcrafts.com
PostPosted: Thu 01 Dec, 2005 1:59 pm    Post subject:         Reply with quote
Well spotted! Yep, it's not only broader (and thinner?) than any I've seen, it does also have that convex profile taper, sort of like an Oakeshott Type XVIII sword blade. So, yes, the tip would normally be more acute on straight taper blades (like Oakeshott XV). On the other hand, the width and profile of my blade resemble the classic Swiss (Holbein) daggers of the same period. Those blades often have a ricasso, however (the one shown below does not). I've often thought that these Arkansas Toothpick blades would serve well in a Holbein project based on examples such as this one:
 Attachment: 8.27 KB
Joe Fults
PostPosted: Thu 01 Dec, 2005 2:27 pm    Post subject:         Reply with quote
Very well done for a McGiver job. :-)
Wonder what it would be like with thicker washers...assuming some could be found.
PostPosted: Thu 01 Dec, 2005 2:38 pm    Post subject:         Reply with quote
Funny you should wonder...I wondered the same thing as I researched and thought about how to do this. Thin, washer-like rondels are historically plausible, but most rondels seem to be slightly thicker and some are quite thick. The second illustration above shows a thick pommel rondel. I didn't find any off-the-shelf washers thick enough to approximate such a rondel but it seems that some rondel daggers featured gaurds and pommels of sandwich construction (thin metal disk, wooden disk, thin metal disk). That would be the easiest way to create thicker rondels with off-the-shelf parts, and it would be historically appropriate, it seems. Perhaps some rondel experts will chime in here and offer details about those weapons. I didn't pursue the design because I don't find it particularly attractive.
PostPosted: Thu 01 Dec, 2005 5:47 pm    Post subject:         Reply with quote
These photos show the piece at various stages of completion. Note the size and length of the tang. Very generous and solid and of a piece with the blade.
 Attachment: 100.41 KB
 Attachment: 43.77 KB
Russ Ellis
PostPosted: Fri 02 Dec, 2005 5:56 am    Post subject:         Reply with quote
Why yes, yes it is... Happy
Greg Griggs
PostPosted: Fri 02 Dec, 2005 9:02 am    Post subject:         Reply with quote
Nice job Sean. Like the way you used simple items to make such a neat piece. FYI - they make what is called a "machine" washer that is readily available which is double the thickness of a normal washer, and are still inexpensive.
Bill Grandy
PostPosted: Fri 02 Dec, 2005 9:42 am    Post subject:         Reply with quote
Wow, Sean, your pictures make it look so simple! I'm almost tempted to give this a try myself!
PostPosted: Fri 02 Dec, 2005 10:12 am    Post subject:         Reply with quote
Sounds perfect for more elaborate work on the rondels-hexagonal shapes, facets & such. Thanks for the tip!
